PreviousNextJavaScript must be enabled to correctly display this content
Web Server Settings
Configure your preferences for the
Oracle Enterprise Communications
Broker's web server using the Modify web-server-config dialog, available from the Web Server icon. Configuration field descriptions are provided below.
Inactivity timeout—Enter the amount of time, in minutes, that the Web GUI must have remained inactive before it ends the Web session. For example, if this timeout value is set as 5, after 5 minutes of no activity, the Web session disconnects. Default is 10. Valid values are 0 to 20. Zero (0) disables this parameter.
The following HTTP state and HTTPS state parameters may have already been set via the GUI installation wizard on your
Broker. You can edit these parameters if required.
HTTP state—Specify whether or not to enable HTTP for accessing the Web server. Default is enabled. A check mark indicates enabled, and a blank box indicates disabled.
HTTPS state—Specify whether or not to enable HTTPS (secure connection) for accessing the Web server. Default is disabled. A check mark indicates enabled, and a blank box indicates disabled.
TLS profile—Enter the Transport Layer Security (TLS) Protocol profile name to use with HTTPS. Valid values are
alpha-numeric characters.
Default is blank.
If you specify a TLS profile, and HTTP is enabled, the
Broker checks against the TLS profile table for a match. If there is no match, the applicable errors display during the verification of the configuration.
