Virtual Systems
The Oracle Enterprise Communications Broker (OECB) Software Only distribution is designed to operate on virtual machines running on generic, off-the-shelf servers. Oracle recommends using the Oracle Virtual Machine (OVM) hypervisor for running the OECB virtual application.
You can install the virtual machine software on the hardware of your choice. The number of VMs supported by a server is constrained only by the resources on your system.
Minimum VM Resources
Each VM instance requires the following minimum allocation or network resources.
- CPU cores: 5
- Memory: 8GB RAM
- Hard drive storage: 40GB
- Interfaces: 4 recommended
These resources support up to 120,000 users in the database.- CPU cores: 8
- Memory: 16GB RAM
Format Hard Drive
Run the command format-hard-drive, as described in the Oracle® Enterprise Session Director Configuration Guide immediately after successful installation.
