PreviousNextJavaScript must be enabled to correctly display this content
Configure the BIOS Setting
The Netra Server
X3-2 requires the following changes to run
Oracle Enterprise Communications
Broker. This procedure shows where to make changes in the BIOS setup
utility.
Set the USB slot
as the first boot device, making the disk controller the second boot device.
Set Hyper-Threading
to
Disabled.
Change Energy
Performance to
Performance.
After setting
Performance, press
Escape to return to
the main menu.
Select
Save and
Exit to apply the changes.
The system reboots using the newly configured settings.
