PreviousNextJavaScript must be enabled to correctly display this content
Single Rear Interface Support
The following procedure explains how to cable a Netra Server X3-2 for
Acme Packet High Availability (HA) node using single rear interface support.
Insert one end of
an Ethernet cable into
wancom1 on the rear
panel of Netra Server X3-2 for Acme Packet #1. The release tab on the RJ-45
jack clicks into place when you insert it properly.
Insert the other
end of the Ethernet cable into the corresponding management interface on the
rear panel of the Netra Server X3-2 for Acme Packet #2 as shown in the
following illustration. For example, If you use
wancom1 on Netra
Server X3-2 for Acme Packet #1, then you connect it to
wancom1 on Netra
Server X3-2 for Acme Packet #2.
HA Node Using Single Rear Interface Support (No Quad GigE NIC)
Refer to the configuration procedures located in the HA Nodes
information in the Configuration Guide.
