Available Connections
Please read all of the information for each of the available connections prior to cabling the Netra X5-2 for Communications.
Port Description You Need
NET (0-3) 10 GigE ports - labeled Net 3, Net 2, Net 1 and Net 0 (left to right). Enables you to connect the Netra X5-2 to your network. A Category 6 (or better) Ethernet cable to connect to the NET 0 port to your network
Network parameters such as an IP address (can be provided by DHCP services or assigned a static address in the OS)
Additional Category 6 (or better) Ethernet cables and Ethernet addresses as needed for additional connections to NET 1 - 3
NET MGT Provides a 10/100BASE-T Ethernet connection to the Service Processor (SP) through an RJ-45 connector. The NET MGT port provides support connections to the SP using the Oracle Integrated Lights Out Manager (ILOM) CLI and Web interface. By default, the NET MGT port is configured to use DHCP to automatically obtain an IP address. Alternatively, you can assign a static IP address to the NET MGT port. To use the NET MGT port, you must configure its network settings. Once configured, use the NET MGT port IP address to log on to the device using a browser or secure shell. Category 6 (or better) Ethernet cable to connect the NET MGT port to your network
IP address for this port (required from DHCP or a static address)
SER MGT (COM1) Provides a TIA/EIA-232 serial Oracle/Cisco standard connection to the SP through an RJ-45 connector. Default settings:
8N1: eight data bits, no parity, one stop bit
115200 baud
Disable hardware flow control (CTS/RTS)
Disable software flow control (XON/XOFF)
A terminal device (e.g., terminal, connection to a terminal server, or computer such as a laptop running terminal emulation software)
A cable to connect the terminal device to the SER MGT (COM1) port
USB Provides USB connections to the SP. The USB ports are hot pluggable, so you can connect and disconnect USB cables from these ports and peripheral devices without affecting server operations. USB keyboard
USB mouse
Note: Maximum USB cable length: 5 meters
VIDEO Provides a temporary video connection to the SP. VGA monitor
HDB-15 video cable with a maximum cable length of 6 meters (19.7 feet)
