Overview
The initial configuration establishes system operations. You can perform the initial configuration of the Oracle Enterprise Communications Broker (OECB) from the GUI.
After you establish system operations, refer to the Oracle Enterprise Communications Broker User's Guide and the Oracle Enterprise Communications Broker User's Guide to configure SIP services and operations, as well as system file management and administrative functions.
