Available Connections
Please read all of the information for each of the available connections prior to cabling the Oracle X7-2.
| Port | Description | You Need: |
| NET (0-2) |
 From left to right:
 Enables you to connect the Netra X7-2 to your network.  |
A Category 6 (or better) Ethernet cable to
				  connect to the NET 0 port to your network
				   Network parameters such as an IP address (can be provided by DHCP services or assigned a static address in the OS) Additional Category 6 (or better) Ethernet cables and Ethernet addresses as needed for additional connections to NET 0, 1 and 2.  |
| NET MGT | Provides a 10/100/1000 BASE-T Ethernet connection to the Service Processor (SP) through an RJ-45 connector. The NET MGT port provides support connections to the SP using the Oracle Integrated Lights Out Manager (ILOM) CLI and Web interface. By default, the NET MGT port is configured to use DHCP to automatically obtain an IP address. Alternatively, you can assign a static IP address to the NET MGT port. To use the NET MGT port, you must configure its network settings. Once configured, use the NET MGT port IP address to log on to the device using a browser or secure shell. | Category 6 (or better) Ethernet cable to
				  connect the NET MGT port to your network
				   IP address for this port (required from DHCP or a static address)  |
| SER MGT (COM1) | Provides a TIA/EIA-232 serial Oracle/Cisco
				  standard connection to the SP through an RJ-45 connector.
				   This interface connects to either Service Processor by default, but can be redirected to the host. Default settings:
A terminal device (e.g., terminal, connection
				  to a terminal server, or computer such as a laptop running terminal emulation
				  software)
				   A cable to connect the terminal device to the SER MGT (COM1) port  |
| USB | Provides USB3.0 connection to the computer. The USB port is hot pluggable, so you can connect and disconnect USB cables without affecting server operations. | Installation media
				   Note: Maximum USB cable length: 5 meters  |
