PreviousNextJavaScript must be enabled to correctly display this content
Adding a License with the Set License Wizard
TLS is the only software feature for which you need a license on the
Oracle Enterprise Communications
Broker. You must obtain a TLS license before you can add it. To obtain a license, you must present the correct system serial number to
Oracle for your license to be generated.
From Configuration home, select
Set license from the
Wizards drop-down list.
The
Broker displays the
Set license dialog.
Copy the serial number for your
Broker and contact your customer support by logging into My Oracle Support or calling Oracle Customer support to make the request. Oracle replies shortly after with your license.
Having received your license from Oracle, enter your license in the Add license field.
The system checks the license and, if correct, installs it. If the license is incorrect, the system tells you.
