Known Issues
The following table lists Known Issues and provides the Service Request ID number, a description of the issue, any workaround, when the issue occurred, and when Oracle fixed the issue. This table includes issues from previous releases that either remain open or are resolved in this release. Issues from previous releases that do not appear here do not apply to this release. You can also find information about resolved issues in the Build Notes for this release.
| ID Number | Description | Found In | Fixed In |
| 27240115 | ECB Sync does not take effect.
Workaround
PCZ2.2.0 | PCZ3.0.0 |
| No ID number |
If you want to establish a High Availability pair that uses IP addresses other than the defaults, perform the following procedure. Use this procedure regardless of whether the ECBs run on virtual or physical systems. The IP addresses you use must be available and valid in your network. If not, you must directly connect the two ECBs before performing this procedure to establish the HA pair initially. Note
Procedure
PCZ3.0.0 | N/A |
| 28314178 |
When you turn on SIP debugging, you may see various unrelated messages displayed on the console. The messages do not prevent the ECB from generating logs, but they can make the console hard to use. Workaround: Use SSH when you turn on SIP debugging. |
PCZ3.0.0 | PCZ3.0.0p6 |
| No ID number |
If you see mapping errors after upgrading, for example errors about redundancy or media traffic, you may need to swap interface addresses. Workaround: Compare the MAC addresses on your Virtual Machine
(VM) to those on your hardware. If the addresses are different, you need to
swap interface addresses. Set the addresses on the hardware to match those from
your VM. Use the
swap command from
the ECB command line.
PCZ3.0.0 | N/A |
| 30576125 | The ECB is reporting session limit inaccurately. | PCZ3.0.0 | PCZ3.0.0p6 |
| 28207606
Registrations that expire at the producer are removed from the registration list. Removal happens when the registration of the endpoint is removed at the producer. The registration should be removed from the consumer the next time the two nodes sync registrations. Normal behavior on learned registrations is that an INVITE arriving at the consumer (learned the registration) is forwarded to the producer (of the registration). The producer then forwards the call to the registered endpoint. If the producer no longer has this registration, it will reject the call. Due to this defect, expired registrations are removed by the producer, but they are not removed by the consumer. The result is that the consumer continues to forward INVITES rather than rejecting them locally. At the producer, the expired registration is removed, and the call is rejected with a 4xx response. If the endpoint in question registers with a third ECB (node 3) that is also configured in the sync mesh, that registration is learned by the same consumer ECB. In this situation, both registrations exist in the learned registration database. One of those registrations is used to route a call. The behavior as to which registration is used is undefined. While the desired behavior is to send the call to node 3, the system may choose the stale registration and forward the call to node 2. |
N/A | N/A |
