Caveats
The following items describe caveats in the P-CZ3.0.0 release.
ECB Sync Compatibility
ECB Sync is supported only between nodes with similar platforms. For example, a mix of X3/X5/X7 is supported, but not a VM and X7.
Deprecated Ciphers
The system deprecates the following ciphers, adhering to recent
OpenSSL changes intended to eliminate weak ciphers:
- All DES-CBC ciphers,
including:
- TLS_DHE_RSA_WITH_DES_CBC_SHA
- TLS_RSA_EXPORT1024_WITH_DES_CBC_SHA
The user should remove any prior version configuration that used these
ciphers, and not configure a security profile with the expectation that these
ciphers are available. Note also that TLS profiles using the
ALL (default) value
to the
cipher-list
parameter no longer use these ciphers.
Your version of the ACLI may still print these ciphers when you run cipher-list ?. Despite printing them in ACLI output, the system does not support them within service operations.
