Caveats, Known Issues, and Limitations
Oracle provides behavioral information that you need to know about the release in the form of caveats, known issues, and limitations. A caveat describes behavior that you might not expect, and explains why the system works in a certain way. A known issue describes temporarily incorrect or malfunctioning behavior, and often includes a workaround that you can use until Oracle corrects the behavior. A limitation describes a functional boundary or exclusion that might affect your deployment.
