Configure Data Sampling Settings for a Dashboard Widget
Confirm that the widget that you want to configure is on the Dashboard. See Add a Widget.
To see SIP and System statistics displayed on a Dashboard widget, the system requires a setting for how often to refresh the display. You can use the default interval or select one from the Auto-refresh interval drop-down list on the widget. Some widgets also display the Table Name drop-down list, where you can set the data sampling frequency. For example, you might configure the widget to refresh the display every 40 seconds and to display the data samples in one minute increments.
- Click the Home tab.
- On the widget, click the Settings icon.
- Select a widget display refresh frequency from the Auto-Refresh Interval (seconds) drop down list.
- If the widget displays the Table Name drop-down list, select a data sampling increment for the widget display.
- Click OK.
