Add a Dashboard Widget
Add a widget to the Web GUI Dashboard to display SIP and System statistics to help you monitor and manage the system.
You can add up to 18 widgets to the Dashboard with the
Add widget control on the Web GUI Home page. The system does not require a reboot after adding a widget to the Dashboard.
If the system displays a warning that adding this widget requires the SIP.Message module to be enabled, the system enables the SIP.Message module when you add the widget.
See "Configure Data Sampling Settings for a Dashboard Widget."
