HMR Import-Export
Due to the complexity of SIP manipulations rules and the deep understanding of system syntax they require, it is often difficult to configure reliable rules. This feature provides support for importing and exporting pieces of SIP manipulation configuration in a reliable way so that they can be reused.
To Import HMRs, use the Upload link on the sip-manipulation list dialog, which is the first dialog displayed after clicking the HMR icon. To export, use Download.
