Exporting
The SIP manipulation configuration contains an
export command which sends the previously selected configuration to the designated file. The syntax is
export [FILENAME]. The system compresses the file with gzip and writes it to the
/code/imports directory.
SIP manipulation configurations can only be exported one at a time.Exported data will look like this:
<?xml version='1.0' standalone='yes'?>
<sipManipulation
name='manip'
description=''
lastModifiedBy='admin@console'
lastModifiedDate='2009-10-16 14:16:29'>
<headerRule
headerName='Foo'
msgType='any'
name='headerRule'
action='manipulate'
cmpType='boolean'
matchValue='$REGEX("[bB][A-Za-z]{2}")'
newValue='foo'
methods='INVITE'>
</headerRule>
</sipManipulation>
To avoid conflicts when importing, the key and object ID are not included as part of the exported XML.
