Go to primary content
Oracle® Communications EAGLE Commands Error Recovery Reference
Release 46.7
E97329 Revision 1
Go To Table Of Contents
Contents
Previous
Previous
Next
Next
E3397 Cmd Rej: ANAME is invalid for type-enttype combo
The enttype=sctpasoc or enttype=ua parameter must be specified before the aname parameter can be specified.
Recovery
Re-enter the rept-meas command that generated this error message, specifying a valid combination of parameters. Refer to the command description in Commands User's Guide for assistance.
