Go to primary content
Oracle® Communications EAGLE Commands Error Recovery Reference
Release 46.7
E97329 Revision 1
Go To Table Of Contents
Contents
Previous
Previous
Next
Next
E2687 Cmd Rej: Inhibit IPSM card(s) before changing the value of param SSH
For the chg-secu-dflt command, the value of parameter SSH can be changed to ON/OFF once the type IPSM cards are inhibited.
Recovery
  1. Enter inh-card command, to inhibit the IPSM card(s).
  2. Re-enter the command that generated this error message, specifying a valid combination of parameters. Refer to the command description in Commands User's Guide for assistance.
  3. Enter alw-card command, to allow the IPSM card(s) to load.
    Contact My Oracle Support for assistance. See My Oracle Support (MOS).
