Go to primary content
Oracle® Communications EAGLE Database Administration - System Management User's Guide
Release 46.7
E97336 Revision 1
Go To Table Of Contents
Contents
Previous
Previous
Next
Next
Install the UNIX/Solaris OpenSSH Software
To install the software on a UNIX/Solaris machine, perform these steps.
  1. The software can also be found at various mirror sites. These sites can be found at this address:
    http://www.openssh.org/portable.html#http
    If you wish to use one of the other mirror sites, select the closest mirror site.
  2. Download this file, openssh-3.7.1p1.tar.gz, from the site selected in 1.
  3. After the file has been downloaded, run the installer and install all the components.
    After the software has been installed, perform the Establishing a Secure Telnet Connection to the EAGLE using UNIX/Solaris OpenSSH procedure.
