Sequence Diagrams
This section provides details about the ISR call setup for a single successful call. This is for informational purposes only.
Non-SIPREC Call
The following sequence diagram applies to the ISR configuration in non-SIPREC, pass-through, interactive voice response (IVR) skip mode. The call applies to a percentage-based recording route.
The simple call flow below reflects a single successful call which applies to a route configured for pass-through mode and recording of 100% of calls. The diagram highlights some of the features in the ISR, such as IVR-skip mode. Previously, the ISR architecture required a VoiceXML platform to make routing, recording and availability decisions. This information now resides locally in the Local Route Cache or is referenced in the database through API commands.
![This call flow is described above. This call flow is described above.](img/GUID-86AA7E2B-FA98-461A-9557-528FF8A9F9C3-default.jpg)
