About the ISR Dashboard
The ISR Dashboard allows you to access, configure, manage, and monitor the ISR in your network, including:
- Manage Recordings
- Manage Reports
- Manage Settings
- Manage Administrator Functions
- Manage Realms
- Manage Accounts
- Manage Routes
- Manage Users
- Manager Sites
- Manage Authorization Services
- View Live Sessions
Requirements Recommendations
To use the ISR Administrator Dashboard, the following must be met.
Browser Requirements
The ISR Dashboard has been tested on the following browsers:
- Google Chrome™ 60.0.3112.113
- Firefox 52.3.0
- Microsoft Edge 11.0.9600.18762CO
ISR recording playback errors have been reported for the following web browsers:
- Firefox—For the (historically) most popular transmission codec, g711, Firefox is not supporting playback of the 8-bit/8 kHz audio format set in the "Default" Recording Format Profile. The playback controls may appear only briefly before becoming unavailable. To address this issue, changes any routes configured to use the "Default" Recording Format Profile to the "Firefox Supported" Recording Format Profile, where the g711 transmission codec is converted to the PCM 16-bit/16 kHz recording format.
Security Features
The following security features have been implemented in the ISR:
- Optional configuration to force cookies through an encrypted (SSL/TLS) session. For a procedure to enable serving pages with SSL, see Appendix C, Enable Serving Pages with SSL.
- Cache-control set to 'no-cache' to avoid possible storage of sensitive data in local browser
- Enforced stronger password controls
- Ability to configure password expiration, user lockout duration, and maximum failed login attempts.
- Removed "hidden" URLs
