Determining the UCID
The Unique Call Identifier (UCID) accurately identifies the specific session related to a request and is the recommended parameter when using any ISR API. It can be one of two values associated with the session: the isr_ucid or ingress_callid. For the isr_ucid, the RSS pulls the SIP Header matching the configured X-ISR-UCID header name from the SIP Headers, if it is present. For a SIPREC session, if the <*:ucid> field is present in the extension data, the parameter value is used as the isr_ucid. In the case where both extension data and X-ISR-UCID SIP Headers are present, X-ISR-UCID SIP Header is used as the isr_ucid. The call-id from the SIP Headers of the initial INVITE is used for the ingress_callid.
There has been a lot of interest (both internal and field-wide) focused on populating SIPREC metadata with an X-ISR-UCID header or a SIPREC extension data field, mainly for purpose of API recording access and control. Currently, there are 2 SPL implementations to address populating the X-ISR-UCID field, one that properly sets the field with a provided UCID/GUID, and another that adds the value as a field in the SIPREC extension data.
The current ISR release has been enhanced to now populate the primary recording X-ISR-UCID field regardless of SPL implementation. However, this has led to confusion with existing integrations.
- X-ISR-UCID (or any other
field name configured in the "<Sip><IsrUcidHeaderField>" tag of the
RSS configuration file
/cxc/vmgConfig.xml), for example:<participant id="hq18GJs3TtJdhjPsfPNV8A=="session="BYiC7uSZQGN3VQdzWI1HWw=="> <nameID aor="sip:sipp@192.168.10.1"> … <extensiondata xmlns:apkt="http://acmepacket.com/siprec/extensiondata"> … <apkt:header label="X-ISR-UCID"> <value>X-ISR-UCID-1-150323161627-1979582260@0a0af9f9</value> </apkt:header> … </extensiondata>
- Third-party UCID, for
example:
<session id="/Bo3JDljRnZluCz1VhPHeg=="> <associate-time>2016-03-15T01:33:46</associate-time> <extensiondata xmlns:apkt="http:/acmepacket.com/siprec/extensiondata"> <apkt:ucid>00FA080200000F56E7667A;encoding=hex</apkt:ucid> <apkt:callerOrig>true</apkt:callerOrig>
- Note that Call-ID no longer
populates X-ISR-UCID automatically, better reflecting behavior in versions
prior to 5.1M6. If you prefer to populate the X-ISR-UCID with the Call-ID
value, you can edit the
/opt/isr/rss/vmgConfig.xmlfile in the following way:<?xml version="1.0" encoding="UTF-8"?> <configuration> … <Sip> … <IsrUcidHeaderField>Call-ID</IsrUcidHeaderField> … <Sip> … </configuration>The following is an example value of Call-ID:<participant id="hq18GJs3TtJdhjPsfPNV8A=="session="BYiC7uSZQGN3VQdzWI1HWw=="> <nameID aor="sip:sipp@192.168.10.1"> … <extensiondata xmlns:apkt="http://acmepacket.com/siprec/extensiondata"> … <apkt:header label="Call-ID"> <value>1-150323161627-1979582260@0a0af9f9</value> </apkt:header> </extensiondata>
