Installation Prerequisites
Before beginning your ISR installation, ensure you have completed the following prerequisites:
- Have at least three servers (physical or virtual) with Oracle Linux Releases 7.2 - 7.6 installed.
- Have access to the ISR rpms:
- isr-Index-<release#>.x86_64.rpm
- isr-Dashboard-<release#>.x86_64.rpm
- isr-rss-<release#>.x86_64.rpm
- isr-Face-<release#>.x86_64.rpm (optional)
You may access these files via https://edelivery.oracle.com.. - Have access to the Ruby 2.4
rpm ( ruby-2.4.0-1.el7.centos.x86_64.rpm ). Ruby is the framework the ISR
Dashboard uses and must be installed as part of the ISR Dashboard installation.
As of Release 6.1M0P5, the ISR supports Ruby version 2.6.4. - Configure a Linux User named isradm on each of the Linux instances created in step 1 to allow you to automatically gain access to config and log files. Once you have configured the isradm Linux user, you must add the user to the "sudoers" group.
- Verify that the hosts you
are installing the ISR components on are connected to the internet.
If your ISR hosts do not have internet connectivity, see "Installing ISR In an Isolated Lab". - Oracle Linux 7 has the yum
package management utility configured by default with access to the
"public-yum.oracle.com" repositories in the file located at
/etc/yum.repos.d/public-yum-ol7.repo. If, for some reason, this file needs to be created, see the Appendix, "Oracle Public Yum Repository Configuration File" in the Oracle Communications Interactive Session Recorder Installation Guide, which contains the specific repository entries. - Configure interfaces;
ISR expects network
configuration to include 4 interfaces, connecting to separate Administration,
Local, Data, and Voice networks. Refer to the Oracle Communications Interactive
Session Recorder Security Guide for more information on networking and trusted
boundaries.
For more information on configuring networking in Oracle Linux 7, see the man nmtui guide and http://www.unixarena.com/2015/04/rhel-7-network-management-nmcli-or-nmtui.html.
- If access to the external
yum repository is gated by a proxy, ensure the
proxy parameter in
the
/etc/yum.conffile is set to:proxy=http://<your_proxy_host>
During the installation process, you will be asked to provide and/or verify the users, passwords and interfaces you created during the Oracle Linux installation. Ensure you have that information before you begin the installation process.
