Creating an Oracle Linux Virtual Machine
This section
describes creating an Oracle Linux Virtual Machine (VM).
To create an Oracle Linux VM:
Download the
"Oracle Linux 7.x for x86 64 bit ISO image" from
http://edelivery.oracle.com/linux.
- Sign in.
- Enter Oracle Linux in the search field.
- From Select Platform choose x86 64 bit and click Select.
- Click Continue.
- Click Continue again if the correct version is displayed.
- Follow the instructions to complete the download.
Open the vSphere
Client and create a new VM.
- Set Configuration to Typical.
- Enter the Name and Location.
- Set Storage to the appropriate datastore.
- Set Guest Operating System to Linux with Version Oracle Linux 4/5/6/7 (64-bit).
- Set
Networks, with the
number of NICs set to
4. Also set the
following networks (all with
Adapter set to
VMXNET3 and
Connect
at Power On selected):
- 1: "VM Network"
- 2: "VM Local"
- 3. "VM Voip"
- 4. "VM Data"
- Set Create a Disk as Thin Provisioned at either the Virtual Disk Size or a different size.
- On the "Ready to Complete" screen, select Edit the virtual machine setting before completion to adjust resources such as Memory and CPUs.
- If necessary, select the "Options" tab's Boot Options menu item to force entry into the BIOS setup screen.
Select
File,
New,
'Virtual
Machine...'
- Follow the Typical instructions.
- Choose Oracle Linux 4/5/6/7 (64-bit) for Guest Operating System.
- Connect the 4 NICs.
- Select Thin Provision for the datastore.
- Click Finish.
Right-click the new
VM and select
Edit
Settings....
- Select the Options tab.
- Select Boot Options from the left panel.
- Check the box under Force BIOS Setup in the right panel.
- Click OK.
- Start the VM.
'Open Console' to
the VM, and you see the BIOS screen.
- Select the Boot table using the arrow keys.
- Move the curser over the CD-ROM Drive and hit the '+' key to move it above the Hard Drive.
- Do not exit BIOS yet.
Within the vSphere
Client, ensure the VM is selected and click the CD icon in the toolbar.
- Select CD/DVD drive 1.
- Select Connect to ISO image on local disk....
- Select the Oracle 7 ISO image downloaded in step 1.
In the console,
Save &
Exit from BIOS.
Installation begins. Follow the instructions provided.
During the installation, the default configuration of partitions allocates almost the entire disk to the "/home" directory. ISR software is installed by default on the path /opt/isr, requiring more space on the root ("/") directory, or more specifically the "/opt" directory. If the Oracle Linux 7 installer defaults are accepted, the ISR components can very easily run out of disk space and not function properly.
