Introduction
This chapter provides information about configuring a Network File System (NFS) share for archival.
To configure archival to an NFS share:
Once the NFS
filesystem is properly being exported by the server, you may try mounting the
share to the client host using the following command:
object.
mount -t nfs -o rw,nosuid <nfs_host_name>:<nfs_mount_path> /opt/isr/ ArchivedRecordings" e.g. mount -t nfs -o rw,nosuid host01.mydoc.com:/usr/ local/apps /opt/isr/ArchivedRecordings
You may need to install the nfs-utils package for mounting an NFS file system. For more information, refer to https://docs.oracle.com/cd/E52668_01/E54669/html/ol7-cfgclnt-nfs.html. -
For the mounted
share to persist through reboots, you must edit the
/etc/fstabfile and add a line to the bottom with the following format:<server>:</remote/export> </local/directory> <nfs-type> <options> 0 0
For example,1.2.3.4:/mnt/nfs_share /opt/isr/ArchivedRecordings nfs defaults 0 0
Use the mount -a command to remount the filesystems and test your configuration. -
From the RSS Linux
shell, verify that users in the group "isr" have write permissions on the NFS
share.
Verify the current user is in the "isr" group (in the following example the user's name is "isradm").
#groups isradm isradm: isradm wheel isr wireshark
Add a file on the share.
touch /opt/isr/ArchivedRecordings/foo.txt
Verify that the file exists
ls -l/opt/isr/ArchivedRecordings/foo.txt
- From the RSS Linux shell, using the systemctl restart tomcatd command, restart Tomcat. Since the Archived Location was not available as a resource to the application server responsible for serving recordings previously, this is necessary.
From the
ISR Dashboard, add the
new Archival Location.
Click the Admin tab.
Click the Manage Sites link.
Click on the displayed Site.
Click on the Locations icon.
Click the Create link.
name—Enter a specific name for the Location.
Recordings Directory—Set the recordings directory path to /opt/isr/ArchivedRecordings.
URL—Set the URL serving recordings in the directory (this is likely to be http://<RSS IP>/ArchivedRecording).
IP Address—Specify the RSS IP address for conversion to play recordings using certain codecs.
Click Create.
From the ISR
Dashboard, configure Archival to the Location.
Click on the Archivers icon.
IP Address—Enter the RSS IP address.
Source Location—Set to <RSS name> (<RSS IP>) Primary.
Destination Location—Set to the name you gave the Location.
Click Create.
For more information on advanced settings while configuring a new Archiver, see Managing Archivers in the Oracle Communications Interactive Session Recorder Administrator Guide.
From the ISR
Dashboard, verify that Archival is configured properly.
Click on the Recordings tab.
Click on a recording to display the details.
Click the File Location tab and verify that the recording was archived in the Archival Remarks field.
By default, the Archival process runs every two minutes and you must wait for it to run at its scheduled time.
