ISR Port Usage
The ISR Platform utilizes the following ports, which are available on the networks displayed in the last column for each component host shown in the following tables.
The following table lists and describes the ports utilized
by all
ISR component hosts.
| Port | Description | Notes | Networks |
| 123 | NTP | N/A | Admin |
by the RSS component host.
| 22* | SSH | SSL | Admin |
| 5060 | SIP Listen Port (Recorder) | N/A | VoIP |
| 8080 | HTTP Webserver | N/A | Data |
| 8443 | Secure HTTP Webserver | SSL | Data |
| 9998 | REST API Listen Port (Recorder) | SSL | Data |
| 9999 | REST API Listen Port (Converter) | SSL | Data |
| 22000-46000 | RTP | N/A | VoIP |
by the Index component host.
| 3306 | My SQL | N/A | Local, Data |
by the Dashboard component host.
| 80 | HTTP Webserver | Disabled/optional | Admin, External |
| 443 | Secure HTTP Webserver | SSL | Admin, External |
by the FACE component host.
| 8080 | Web Service Port | Disabled/optional | Data |
| 8443 | Web Service Port | SSL | Data |
The ISR does not use port 22 within its system, however, it is typically open in the firewall for administrative connectivity.
