ISR Dashboard Cookies
Dashboard cookies are set by default with a domain attribute of the empty string with the path attribute set to /. This results in a "host-only" cookie, with no subdomains included. ISR Dashboard administrators may need to manage these domain and path settings for security or functional purposes.
To configure Dashboard cookie attributes for specific domains and paths,
create a backup file, and then edit the following file:
/var/www/dashboard/current/config/initializers/session_store.rbInclude the domain and path attributes after the "key" entry, separated by a comma.
