Configure Fault Email Notifications
Oracle Communications Session Delivery Manager can trigger automatic email notifications when reporting alarms for certain severities. You can configure the appropriate email addresses that match each alarm severity.
You must configure the SDM mail server before you can use this feature. See the Configure the Mail Server section in the Oracle Communications Session Delivery Manager Installation Guide for more information.Configure Email Notifications for Fault Occurrences
With appropriate administrator privileges assigned, you can assign fault email notifications.
Delete Fault Email Notifications
With appropriate administrator privileges assigned, you can delete fault email notifications.
- On the main menu, click Settings, Faults, Fault email notifications.
- In the Fault email recipients dialog box, select the email address you want to remove and click Delete.
- In the Delete dialog box, click Yes.
- In the success dialog box, click OK.
- In the Fault email recipients dialog box, the email address no longer appears in the table. Click OK.
