Enable Alarm Synchronization
Use this task to retrieve alarms you may have missed from devices, if SDM was unavailable for a limited time period.
Pre-requisites:
- You must have administrator privileges to do this task.
- On the individual devices SDM manages that support alarm synchronization, you must specify how many days to keep traps by using the trap-event-lifetime parameter.
- On the Oracle Communications Session Delivery Manager navigation bar, select Device Manager, Devices.
- In the Managed Devices - Group View table tree, expand the tree and click the device for which you want to enable alarm synchronization.
- Click Admin, Synchronize alarms.
- In the Synchronize alarms dialog box, click Yes.
- In the success dialog box, click OK.
- Expand the Security Manager slider and select Audit log and View to verify if the alarms are synchronized.
