Alarm Specific Configuration Tasks
Alarms play a significant role in determining the overall health of the system. An alarm is triggered when a condition or event happens within the hardware or software of a system (node). Alarms contain an alarm code, a severity level, a textual description of the event, and the time the event occurred. The following sections describe how to configure the way alarms display in Oracle Communications Session Delivery Manager.
Configure the Auto Refresh Period for Alarm Data
Oracle recommends that the use of the auto refresh function is limited to two users or less, due to the functional expense of this operation.Add an Annotation to an Alarm
- Expand the Fault Manager slider and select Alarms.
- In the alarms table, click the alarm to which you want to add explanatory note and click Edit.
- In the Edit annotation dialog box, add your explanatory note about this alarm in the Annotation field.
- Click OK.
Enable Alarm Acknowledgment
The appropriate administrator privileges must be assigned to acknowledge alarms.
- In the alarms table, select the alarm that you want to acknowledge and click Acknowledge.
- In the Acknowledge dialog box, click Yes.
- In the Info dialog box, click OK.
- Click the alarm to view an updated Alarm detail dialog box with the Acknowledged by and Last modified fields updated.
- Click OK.
Disable Alarm Acknowledgment
The appropriate administrator privileges must be assigned to unacknowledge alarms.
- In the alarms table, select the alarm that you want to unacknowledge and click Unacknowledge. The Acknowledge dialog box appears.
- In the Unacknowledge dialog box, click Yes.
Clear an Alarm
The appropriate administrator privileges must be assigned to clear alarms.
Clearing an alarm in Oracle Communications Session Delivery Manager has no affect on the node because the node is unaware that Oracle Communications Session Delivery Manager displayed the alarm or changed its severity to clear.- Expand the Fault Manager slider and select Alarms.
- In the alarms table, select the alarm that you want to clear and click Clear.
- In the Clear dialog box, click Yes.
Audible Alarms
The audible alarms system allows you to set off an audible sound when an activated alarm is triggered.
Alarm events are updated during each refresh cycle of the alarms table. Search functionality is disabled when audible alarms are active. The audible alarms cease to function upon exiting the Fault Manager navigation bar slider.
Audio Files
The Audible Alarms application comes with five alarm sounds (one for each severity). You may replace these files with your own files as long as the files retain the same filenames and are in a Waveform audio file format. The files are located in the following directory:
<installed directory>\ACMEConsole\audibleAlarms
The filenames appear as:
- Audio_Emergency.wav
- Audio_Critical.wav
- Audio_Major.wav
- Audio_Minor.wav
- Audio_Warning.wav
Change the Default Severity Alarm Colors
- On the main menu, click Settings, Alarms, Alarm Colors.
- In the Alarm colors dialog box, click the Color drop-down list next to the severity category and its default color.
- In the pop-up color palette, click the new color that you want for the alarm.
- Repeat the previous two steps if you want to configure more severity alarm colors.
- Click OK.
- In the success Information dialog box, click OK.
