Remove a Cluster Node
Oracle recommends that you perform this task during a planned downtime, such as a maintenance period to avoid system disruption.- Log into the SDM GUI on a node belonging to the running cluster.
- Select Tools, Health Monitor.
- In the Health Monitor Console pane, view the Heartbeat Summary table to know which node is cluster member node that is running the master databases.
- Log into the node to be removed from the cluster as the nncentral user.
Change directory to
the bin directory.
For example:
cd /home/nncentral/AcmePacket/NNC8x/bin
Execute the
shutdownnnc.sh
script.
./shutdownnnc.sh
Uninstall
SDM.
./uninstall.sh
Shut down all
remaining nodes starting with the replicas, followed by the master cluster
member node.
./shutdownnnc.sh
Switch to the root
user on the master cluster member node and enter the root user password when
you are prompted.
su root
From the bin
directory on the master cluster member node, execute the
setup.sh script.
./setup.sh
- Enter 2 for the Custom option and press Enter.
- Enter Yes to continue.
- Enter 6 for the Cluster management option and press Enter.
- Option 1 Configure and manage members in a cluster is selected by default. Press Enter.
- Enter 2 for the Remove all remote members option that removes all remote cluster member nodes from the cluster configuration and press Enter.
- Enter 1 for the Proceed with removing all remote members option and press Enter.
- Enter 3 for the Apply new cluster configuration option and press Enter.
- Enter 3 for the Quit out of cluster configuration option and press Enter.
Switch to the
nncentral user on the master cluster member node.
su nncentral
Execute the
startnnc.sh script
./startnnc.sh
- Execute the startnnc.sh script on each remaining replica node in the cluster.
