Rejoin a Cluster Node Manually
Use this task to rejoin a cluster node manually with the cluster when this node is down for more than 24 hours, has a failure, or it is stopped.
Oracle recommends that you perform this task during a planned downtime, such as a maintenance period to avoid system disruption.
Next
Steps
- Select Tools, Health Monitor and view the Heartbeat Summary table to check SDM cluster member node processes.
- Begin using
SDM. Use your web
browser to navigate to the server login page by entering the host name or IP
address, and port number in the web browser navigation bar. For example:
http://example.com:8080
In the login page, enter the administrator login name and password that you configured in the Configure User Account Passwords section. -
After the server starts after the backup of its databases, it attempts to synchronize all plugins installed on the local file system again. Select Tools, Plugin Management in the SDM GUI to ensure that all plugins are working properly in the Element Manager Plugins table.
