Start the Easy Installation
Navigate to the
Oracle Communications Session
Delivery Manager installation bin directory.
For example:
cd /<sdm-install-directory>/AcmePacket/NNC<version>/bin
Run the setup
application with the setup.sh script.
./setup.sh
A warning message appears if you have less than the recommended minimum physical memory. Proceeding without the recommended minimum physical memory may result in performance degradation.WARNING:
This process may take several minutes to complete. Interrupting the setup.sh process risks corrupting the system. - Complete the OCSDM installation and press Enter to continue.
Select option 3,
Easy-Install. Press
Enter to continue.
[ ] 1 - Typical : Runs through most common set up options. (Recommended) [Default] [ ] 2 - Custom : Allows manual customization. (Advanced users) [X] 3 - Easy-Install : Prompts user for minimal setup option values. [ ] 4 - Quit : Finish and quit setup.
