Easy Installation
The Easy-Install option is provided for an Oracle Communications Session Delivery Manager (OCSDM) server installation that has specific, simplified setup options.
The Easy-Install option can be used to deploy an OCSDM instance with basic configuration options to run Oracle Communications Session Element Manager and Oracle Communications Route Manager. Additional installation steps are required for Report Manager and a more comprehensive set of options is offered for the Typical and Custom installation options in the setup program.
We recommend that you record all the setup parameters that you configure in this chapter. You will need to use them again the next time you upgrade OCSDM and run the Easy Install.Complete the following tasks before you begin this installation:
- Complete all applicable tasks in the Pre-Installation Tasks chapter.
- Configure the NNCentral account. Refer to the Configure the NNCentral Account section for more information.
- You must unzip the tar file to create the OCSDM installation directory, which contains the installation program used to run the installation. Refer to the Create a Session Delivery Manager Installation Directory section for more information.
- Ensure that this installation is the type of installation that you want to do. Refer to the Select Installation Type for Session Delivery Manager section for more information.
