Specify the Setup Properties File
You can edit the
user_setup.properties
file, which has pre-defined server installation inputs that you specify. The
headless installation setup script points to and uses this file later to
install
OCSDM on your server.
After you complete the Headless Installation and decide to run the Typical or Custom Installation, any changes that you make in these installations are not propagated to the user_setup.properties file. The changes you made in the Typical or Custom Installation need to be added to the user_setup.properties file to keep this file current in the event that you need to use this file again in a future headless installation.
