Start the Headless Installation
- Login to your server as the root user.
Navigate to the
Oracle Communications Session
Delivery Manager installation bin directory.
For example:
cd <sdm-install-directory>/AcmePacket/NNC<version>/bin
Run the setup
application with the
setup.sh scriptwith the headless syntax and the full path to theuser_setup.propertiesfile that you specified for this installation. For example:./setup.sh --headless /home/AcmePacket/NNC<version>/conf/setup/user_setup.properties
A warning message appears if you have less than the recommended minimum physical memory. Proceeding without the recommended minimum physical memory may result in performance degradation.WARNING:
This process may take several minutes to complete. Interrupting the setup.sh process risks corrupting the system.
