Upgrade to a Supported Version of Linux
Use this task if you have an unsupported version of Linux that needs to be upgraded to a supported version of Linux so you can install Oracle Communications Session Delivery Manager on your server.
Upgrade Linux on Your Server
Use this task if you need to upgrade the Linux server operating system on your server in order to upgrade Oracle Communications Session Delivery Manager.
Ensure that the server is shut down before you do this task. See the Shut Down Your System section for more information on shutting down the OCSDM server.
