Check the File Descriptor Count on Your Linux System
The Oracle Communications Session Delivery Manager server requires that the Linux system, on which it is installed and runs, have 20,000 file descriptors.
- Login to the server as the nncentral user.
Use the
ulimit -ncommand to view the number of file descriptors configured for your Linux system.ulimit -n
- If the output displays a value of 20000 or greater, you are finished with this task. If the output value is less than 20000, continue to the next step.
Navigate to the
OCSDM installation bin
directory.
For example:
cd /<sdm-install-directory>/AcmePacket/NNC<version>/bin
Run the
shutdownnnc.sh
script. By default, the shutdownnnc.sh script detects whether the existing
installation is a standalone or clustered system and prompts you with the
option to shut down the entire cluster if no flag options are provided.
However, You can script an option ahead of time by adding -local for single nodes and -cluster to shutdown an entire cluster../shutdownnnc.sh Shutdown back-end server Do you wish to shut down the entire cluster (Yes/No)? Yes
- Login to the server as the root user.
Open the
limits.conf file in the
/etc/security/directory to check if there is any line in the file withsoft nofileorhard nofileentries. For example:/etc/security/limits.conf #<domain> <type> <item> <value> * soft nofile 20000 * hard nofile 20000
If there are no
values after the
nofileentries or these entries are less than 20000, enter each entry as shown above. - Exit the shell.
Use the
ulimit -ncommand again to view the number of file descriptors that you configured (the command should now return a value of 20000). - If you have a cluster setup, repeat the previous steps for each cluster member.
