Start the Typical Installation
Select option 1,
Typical. Press Enter
to continue.
[X] 1 - Typical : Runs through most common set up options. (Recommended) [Default] [ ] 2 - Custom : Allows manual customization. (Advanced users) [ ] 3 - Easy-Install : Prompts user for minimal setup option values. [ ] 4 - Quit : Finish and quit setup.
