Typical Installation
The following tasks are accomplished in the Typical installation to specify the most common setup properties to get a basic Oracle Communications Session Delivery Manager installation running on the server.
- The setup program loads and
installs the appropriate product plugins (if you are upgrading
OCSDM from a previous
version).
If you are installing OCSDM for the first time, the appropriate product plugins must be installed after the OCSDM server installation. See the Manage Product Plugins chapter in the Oracle Communications Session Delivery Manager Administration Guide for more information. - Configure passwords for the
default user accounts.
Verify that you have the correct sudo password before you do this task. - Configure the global identifier.
- Configure HTTP or HTTPS (default) on the Apache web server.
- Configure the SNMP Trap Relay port for Fault Manager.
Once you have accomplished the applicable tasks, and the required configuration of the NNCentral account in the Pre-Installation Tasks chapter, you are ready to begin this installation. We recommend that you record all the setup parameters that you configure in this chapter. You will need to use them again the next time you upgrade OCSDM and run the Typical installation.
