Upgrade the Session Delivery Manager Cluster
Ensure that you are currently running OCSDM, Release 7.5M3. If you are running any version of OCSDM prior to Release 7.5M3, you cannot install OCSDM Release 8.x. Use following summary of tasks to upgrade your
OCSDM server cluster:
- See the Session Delivery Manager Software Distribution Media section in the Oracle Communications Session Delivery Manager Release Notes for more information about the names and descriptions of the software files that you need to do this upgrade.
- Download the OCSDM application image file to each OCSDM server cluster node in the same base directory in which the previous software was initially installed.
- You must unzip the tar file on each node to create the OCSDM installation directory, which contains the installation program used to run the installation. Refer to the Create a Session Delivery Manager Installation Directory section for more information.
- If you are upgrading Report Manager, the Oracle Database and Oracle BI Publisher must be running before you upgrade OCSDM so that Report Manager database data is migrated.
- Start the installation on the master cluster node and migrate the application data from the previous release to this master cluster node.
- Continue the installation on the master node.
- Migrate the application data from the previous release to each cluster replica node.
- With the introduction of OCSDM, Release 8.0, you must select one server to start in the cluster only (which in this case is the master node). Once this server is started and operational, you can start the other server(s) in the cluster.
Start the Session Delivery Manager Cluster Upgrade
The previous release of Oracle Communications Session Delivery Manager must manage at least one device to be upgraded successfully.Migrate Application Data on the Master Cluster Node
Transfer the application data on the master node (member) of the cluster system.
Migrate Application Data on Each Cluster Replica Node
Transfer the application data to each replica node (member) of the cluster system.
Pre-requisites: Ensure that you have shut down the server, downloaded and unzipped the application image file, and started the setup application on the replica node before starting this task.
Transfer the Migrated Application Database Backup to the Replica Node Manually
Use this task if you opted not to copy the migrated database archive when you migrated application data on the master cluster node when upgrading OCSDM from a previous release.
- Log into the replica node, shut it down and do a backup of the application database (also known as a cold backup). See the Backup Databases on a Shutdown Server section in the Session Delivery Manager Server Database Maintenance chapter of the Oracle Communications Session Delivery Manager Administration Guide for more information.
- Migrate the application data on this replica node from the backed up application database. See the Migrate Application Data on Each Cluster Replica Node section in this chapter for more information.
- Repeat the previous steps for any remaining cluster node.
