Headless Installation
The Headless Installation of Oracle Communications Session Delivery Manager is a fast, simplified installation process that runs without the setup application. Use the tasks in this chapter to specify the user_setup.properties file and run a setup script that points to this file. When you run the setup script, OCSDM is installed on your server.
Complete the following tasks before you begin this installation:
- Complete all applicable tasks in the Pre-Installation Tasks chapter.
- Configure the NNCentral account. Refer to the Configure the NNCentral Account section for more information.
- You must unzip the tar file to create the OCSDM installation directory, which contains the installation program used to run the installation. Refer to the Create a Session Delivery Manager Installation Directory section for more information.
- Ensure that this installation is the type of installation that you want to do. Refer to the Select Installation Type for Session Delivery Manager section for more information.
