Complete the Easy Installation for a Cluster
- At the Cluster management part of the easy installation, when you are asked if this server is to be a member of a cluster, select Yes (option 1) by entering 1 and press Enter.
- When prompted to continue, type Yes.
When prompted,
enter the IP address(es) of each cluster member separated by a comma and press
Enter. For example:
10.10.10.2, 10.10.10.3
- When prompted, enter the Secure File Transfer Protocol (SFTP) password, which is the clear-text nncentral user password and press Enter. Refer to the Configure the NNCentral Account section in the Pre-installation Tasks chapter for more information.
- Re-enter the SFTP password to confirm it.
