PreviousNextJavaScript must be enabled to correctly display this content
Select the GUI Installer Method
Select either X11 forwarding using secure shell (SSH) or the virtual network computing (VNC) to do installations with a graphical user interface (GUI) installer on your Linux system.
Configure SSH with X11 Forwarding
You can use either the -X or -Y flag to enable X11 forwarding through SSH when you log in as the root user. For example:
ssh –Y root@server-name
If you do not have DNS on your server or the server name does not work, enter the IP address of the server.
(Optional) Install the
xorg-x11-xauth package (if it is not already installed). For example:
yum install xorg-x11-xauth
You can use either the -X or -Y flag to enable X11 forwarding through SSH when you disconnect and log in as the oracle user. For example:
ssh -Y oracle@vm
Find the values for the DISPLAY variable with the
xauth list command.
$ xauth list
<domain name>/unix:11
<domain name>/unix:10
In the example above, either 11 and 10 are suitable values for the DISPLAY variable.
Configure VNC
You can use either the -X or -Y flag to enable X11 forwarding through SSH when you log in as root. For example:
Install the Desktop package group, which includes X11 and gnome-desktop. For example:
