Register a Local Standalone Installation of BI Publisher for Report Manager
If you entered local standalone in the previous section, use this additional task to register a local standalone installation of Oracle BI Publisher for Report Manager:
In the Register BI
Publisher Step 2 of 2 pane, complete the following installation details fields
Manager:
Server Protocol drop-down list Select http or https for the secure hypertext transfer protocol. Server Location field The host name. Note:
This value should be the same host name used when creating the certificate (For example, server1.oracle.com).Server Port field The Oracle BI Publisher server port number. For example, 7002. BI Publisher Home Folder field The BI Publisher Home Folder. For the installation previously documented, the path is /app/OracleMiddleWare/user_projects/domains/bifoundation_domain
. The path for your installation may differ if you selected a different location for the OracleMiddleWare directory.Repository Location field The repository location that can be found by logging into BI Publisher and navigating to Administration > Server Configuration > Catalog > Path. For the installation previously documented, the repository location is /app/OracleMiddleWare/user_projects/domains/bifoundation_domain/config/bipublisher/repository
.Note:
The 'nncentral' user must have write privileges for the BIP home folder and repository location.BI Publisher Schema Prefix field The prefix schema for BI Publisher. The default prefix is DEV. Oracle Database User Name field The nncentral user name for your Oracle database. See the Add an Oracle Database User that Connects to BI Publisher for Backup and Restore Functions section for more information. Oracle Database User Password The password for the nncentral database user. Oracle Database Service Name The Oracle database service name. Unless you previously selected a different name, enter AcmeBIPublisher. Oracle Database Home Path Enter the Oracle database home path. For the installation previously documented, the Oracle database home path is /app/oracle/product/11.2.0/dbhome_1
.Oracle Database SID Enter the Oracle database SID. The SID is the first 12 characters of the Oracle Database Service Name. If AcmeBIPublisher is the Oracle Database Service Name, enter AcmeBIPublis. - Click Apply.
