Register BI Publisher in Session Delivery Manager
After the Oracle Communications Session Delivery Manager installation, Oracle BI Publisher must be registered from within the SDM GUI application.
Start the Oracle
Communications Session Delivery Manager server as the nncentral user:
cd /opt/AcmePacket/NNC<version>/bin/ ./startnnc.sh
- Navigate to your SDM server IP address on port 8080.
- Click Report Manager > Register BI Publisher.
- In the Registered BI Publisher pane click Configure Registration.
In the Register BI
Publisher Step 1 of 2 pane, complete the following installation details fields
to register a BI Publisher server:
Installation Location radio buttons Select the following location type: - local—The Report Manager and BI Publisher software is installed on the same server.
- remote—The Report Manager and BI Publisher software is installed on separate servers.
If you are registering BI Publisher with SSL on a local server, a domain name server (DNS) is required.Installation Type radio buttons Select the following installation type: - standalone—A single or remote installation of Oracle Communications Session Delivery Manager, Oracle BI Publisher, and their respective databases that work together to generate reports.
- cluster—A cluster of servers (local or remote) that generate reports and provide high availability in case one system experiences a sudden failure. On each server that is part of the same cluster, Oracle BI Publisher and Oracle Communications Session Delivery Manager are installed with their respective databases.
Weblogic Admin User Name field Enter the Weblogic administrator user name that you created when you installed Oracle BI Publisher. Weblogic Admin Password field Enter the Weblogic administrator password that you created when you installed Oracle BI Publisher. Admin User Name field This is the user name that you entered when you configured BI Publisher security. Admin Password field Enter the Oracle BI Publisher administrator password that you created when you installed Oracle BI Publisher. - Click Next.
The available configuration parameters for Step 2 of 2 depend on your selections in Step 1 of 2.
