Install Oracle BI Publisher
- Start the Oracle BI Publisher installer.
- If setting up a local or remote standalone, follow the directions in the Create a Standalone BI Publisher section.
- If you are setting up a local cluster, follow the directions in the Create a BI Publisher Cluster section.
- If you are setting up a remote cluster, follow the directions in the Create a BI Publisher Cluster section.
- Verify your access to BI Publisher.
- Configure privileges for the nncentral user and oracle user.
- If you installed a local standalone or local cluster, set up a data pump directory.
If you encounter errors during the installation process, see the Administrator's Troubleshooting Guide for BI Publisher.
