PreviousNextJavaScript must be enabled to correctly display this content
Register a Local BI Publisher Cluster
If you entered the
local and
cluster options in
the
Register BI
Publisher Step 1 of 2 pane, complete the following task:
Select the local
cluster node and click
Edit.
In the
BI
Publisher Cluster Member window, enter the protocol, IP address,
port, FTP user name, FTP password, BI Publisher home folder, repository
location, and Oracle database information for each node in the cluster.
If setting up
a local cluster, the BI Publisher server information is pre-populated.
Click
Apply to save and
close the
BI
Publisher Cluster Member window.
