Register a Remote BI Publisher Cluster
If you entered the
remote and cluster options in the
Register BI Publisher Step 1 of 2 pane, complete
the following task:
- Select the remote cluster node and click Edit.
- In the BI Publisher Cluster Member window, enter the protocol, IP address, port, FTP user name, FTP password, the BI Publisher home folder, and the repository location for each node in the cluster.
- Click Apply to save and close the BI Publisher Cluster Member window.
- Click Apply.
