PreviousNextJavaScript must be enabled to correctly display this content
Remote Cluster Configuration
To configure BI Publisher in a remote cluster, run the Node
Manager and then start the Managed Servers.
Repeat steps 1 through 3 for each node in the cluster before moving on
to step 4.
SSH to your BI
Publisher server.
Navigate to the
WebLogic bin directory.
cd app/OracleMiddleWare/user_projects/domains/bifoundation_domain/bin/
Run the
startNodeManager script with an appended ampersand.
./startNodeManager.sh &
WARNING:
each node in the cluster before continuing.
Navigate your
browser to BI Publisher's Admin Console at
http://<IP
address>:7001/console.
In the
Domain
Structure section of the pane, click to expand the
Environment menu and
click
Servers. For
example:
In the
Summary of Servers section of the pane, click
the
Control tab, and click the available server
nodes and click
Start to start the
managed WebLogic server.
