How to Start, Stop, and Check the Status of the Oracle Database Listeners
Log in as the
Oracle user.
ssh -Y oracle@myserver
Use the export
ORACLE_HOME variable to restart the listener. Ensure that this variable
identifies (set to equal) the directory path on which you installed the Oracle
database software. For example:
export ORACLE_HOME=/home/oracle/app/oracle/product/<oracle-database-software-version>/dbhome_1 cd $ORACLE_HOME/bin
Start the BI
Publisher database listener (LISTENER).
./lsnrctl start
Start the OCSDMDW
database listener (LISTENER2).
./lsnrctl start LISTENER2
To check the status
of either listener mentioned above, use the following command:
./lsnrctl status
